Help Identifying A This Dome
Graham750
Satsuma01 is quite correct. The Dome is a Dennard
See page 5 on the following manual:
http://www.norbain.co.uk/downloads/manuals...System_WE_1.pdf
You will notice on the OUTLINE SPECIFICATION, it makes a reference to DEN PANEL & BAX PANEL protocol converters.
Speak to DM Tech support on 0845 600 9502 or via email uksupport@dmicros.com
Now its just down to identifying the actual Dome model.
Hope this helps.
Regards
Stu
Kind regards
Stuart Onley
SAMS Consultancy
Independent Security Consultants
email:enquiries@samsconsultancy.co.uk
website:www.samsconsultancy.co.uk
Guys wanted to thanks for your help, with your advice i managed to get P/T/Z control of the dome via coax. Only thing left is to work out how to get in to the menus i dont have a keyb only using a DS2.
cheers
I still had no luck identifying the dome so have added a couple more pics, thanks for the advice so far guys appreciated.
Didnt recognise the dome, but the backplates Dennard.
you will need a keyboard or a newer ds2 that is netvu based, as you can gain access to the menus via the software.
I have a DS2 version 3.1 (169) netviewer software and netvu but I undertsand not features are available with this box but I do have telementry control, but not sure what command would bring up the menu, have read that it should be either * or shift and wash but to no avail.
[/quote
ah found this
This
