Guest tjmartin Posted June 14, 2004 Posted June 14, 2004 can anyone help??? I have a veritas 8c alarm in my house - it recently stopped working , when I tried to set it or push any buttons it made a harsh beeping sound (not the usual sound for setting) so in an attempt to reset the alarm I cut off its power. however when I turned the power back on it beeps for about 5 mins and then the alarm goes off. can I do anything - is there a factory code that needs to be input or is this a job for a technician?? any help appreciated., , Tom
FASTCAR Posted June 14, 2004 Posted June 14, 2004 Hi , It sounds like you could have a flat battery , which has caused your panel to crash!.If it is more than 3 years old ,get the original installer to come and service the system , check the panel , and replace the battery. B)
