Guest Barn Posted June 15, 2004 Posted June 15, 2004 Whenever the alarm is not set, and I move into zone 4 it beeps. This does not happen in the other zones or when the alarm is set. Does anybody know how I can stop it from doing this?? Any help would be greatly appreciated
Paul Giles Posted June 15, 2004 Posted June 15, 2004 Zone is on chime, ring your installer or read your user manual. Regards Paul PG Security Systems Somerset SSAIB Certificate of Merit Installers. www.pgsecurity.co.uk
Guest Guest Posted June 15, 2004 Posted June 15, 2004 Sounds like you may have chime programmed for that zone. Press chime button and then 0 this will cancel chime selection, if you want chime on your doors press chime and then the appropriate zone No. Biker C
Guest Guest Posted June 15, 2004 Posted June 15, 2004 Thanks a lot for the help Fixed now B) I can sleep in peace now when people pass through zone 4 for the toilet
