Change Inspiration Pin
frankpinto
hello
I shifted a BT inspiration, but need to alter some programming steps, the code has been changed from 1111 and need to reset this can anybody tell me how to default the system so that i can start from scratch.
frankie
:oops:
So it is ...... Hey, hang on then ... I might have that on PDF.... I'll have a look.
Here is the BT Pathway instructions ... it's virtually the same as the Inspiration
BT_Pathway_Owners_Man.pdf
:oops:
I can unlock the code, but it does also default the system. Not a huge issue if you do not have a huge address book or complicated ring groups or least cost routing.
I prefer not to give this info out on a forum where it will remain, and actually do charge a small fee to do this.
Email : martin@askthetrades.co.uk
a small fee is no problem, there is basic programming to re enter.
send me an email xxxxxxxxxxxxxxxxxxxxx
Regards.
