Wireless Alarm System
spg
Hi, anyone know of a wirless alarm that has led lights on it that light up when a zone is activated in day mode, objective is to know which sensor has activated.
You could go for Menvier M 600 add on a MR node for wireless zones required and add a CPA 6 modual giving 8 out puts (plus all the panel out puts ) or just put in walk test during the day and the key pad will tell you whitch zone active
www.AllanMoncrieffAlarms.com
the Visonic powermax wireless system gives a text indication of the zone that caused the alarm.
Thanks for help mate.
Thanks also for the help cheers
Most wireless system have an LCD display that will give you this information. The ESP prime is one of the newer systems worth having a look at.
Sttigg.
