MIKE210649 Posted November 16, 2008 Posted November 16, 2008 I fitted a accenta /optima alarm system a few weeks ago it worked ok but it goes into alarm on the same zone, every time it is set ,at various times of the night, can you help me mike
lawandorder Posted November 16, 2008 Posted November 16, 2008 MIKE210649 said: I fitted a accenta /optima alarm system a few weeks ago it worked ok but it goes into alarm on the same zone, every time it is set ,at various times of the night, can you help me mike While you're waiting for Mike to answer I will try to help. What is connected to the zone in question? If it's a PIR it is well worth removing the cover and checking for spiders, even the smallest of insects cause problems if they get inside the case and it's surprising how small a gap they can get through. Also worth checking the siting of the detector in relation to any draughts or heat sources.
A-G Posted November 16, 2008 Posted November 16, 2008 Mike You said it activates at night ..... could it be a sensor that should be isolated at night, eg. landing, bedroom? . . . PM me for access to the SSAIB members discussion area.
