Veritas 8 - Alarm Sounding Time
MBroome
It is possible to change the time it takes for the alarm to sound when entering a property? I've recently purchased a new house with an Veritas 8 alarm with the control panel fitted by the front door, but I often use the back door as entry and don't have time to make it from the back door to the panel to de-activate the alarm before it sounds. It sounds in approximately 5 seconds and I was wondering if there was any way to change it to give me say a 10-15 second delay?
Any help will be very appreciated. Thanks in advance,
Mark
sounds like the back door isn't set up as a entry route. This can be changed as well as the entry delay in the engineer menu. however, you will need the engineer code (not user code) to do this
Mark Terry
A.M.I. Security
Covering the Thames Valley
Tel. 01189 775173 24hours
mark.terry@amisecurity.co.uk
Yup, just give them a call and they'll be able to help you out, probably be a small fee involved since your not on their books as service customer.
cheers, thanks for the quick reponses.
How do maintenance contracts work for alarms? A monthly fee but if there are any problems they'll come out and sort it for no extra cost?
Depends on the contract, but usually yes.
For example we do a comprehensive (as you say above all faults of the system covered) but would charge if you had caused it ie water in sensor etc
But comp is only available on equipment we have supplied, so is the std on all new systems.
We then offer std which services the system every 12 (or 6) months and does not cover parts etc. This is then upgraded to hybrid (where the parts we have replaced are comprehensive and the rest std.
James
