kitoto Posted November 20, 2008 Posted November 20, 2008 Hello great geniuses, Having problem triggering the HYL004 autodialler from scanny 9651. I have used 9651 op1 but noting happens when I set the alarm off or tamper I have checked the voltage +12v term to op1=no volts, op2 no volts, op3 ..12v The dialler needs switched neg ie 0v to trigger which works when I apply 0v on TR1 or TR2. I have measured the comms op as well with no neg voltage eighter. Is there a delay before it activates a neg to op1 or op2 as I don't know much about the scanny. I am trying to sort out this for a friend and any help would be most gratefully appreciated. tanx in advance freddy
hpotter Posted November 20, 2008 Posted November 20, 2008 How you triggering the 9651? Try triggering a PA (temp fit one if need be {bit of wire?} - zone 8 default = PA). Check comms ch2 (orange wire) see if goes 0v on PA trigger. PA triggers bypass any inadvertent prog delays. (I take it your powering dialler from the panel, if not link 0v panel & psu).
kitoto Posted November 20, 2008 Author Posted November 20, 2008 How you triggering the 9651? Try triggering a PA (temp fit one if need be {bit of wire?} - zone 8 default = PA). Check comms ch2 (orange wire) see if goes 0v on PA trigger.PA triggers bypass any inadvertent prog delays. (I take it your powering dialler from the panel, if not link 0v panel & psu). Hi, I am triggering via the tamp spring switch ie like removing the cover. Powering the dialler from the 9651 board aux. I will try out this weekend thanks. Will the tamp work same as alarm activation. Freddy
Alarm Co Posted November 20, 2008 Posted November 20, 2008 plug on coms lead , connect intruder output of lead to dialler, set alarm trigger it bingo,, the tamper will not trigger op1 as only gives internal alarm only ie internal speaker no ext bell op1 shld be the bell output only gaves off / triggerd when alrm fully set then activated or tested
kitoto Posted November 21, 2008 Author Posted November 21, 2008 plug on coms lead , connect intruder output of lead to dialler, set alarm trigger it bingo,, the tamper will not trigger op1 as only gives internal alarm only ie internal speaker no ext bell op1 shld be the bell output only gaves off / triggerd when alrm fully set then activated or tested Thanks again Freddy
kitoto Posted November 27, 2008 Author Posted November 27, 2008 Hi, Connected as you said and all seems ok. Thanks.
hpotter Posted November 27, 2008 Posted November 27, 2008 Thanks for the feedback. Bit worried about the "seems" though!
