kernowjim Posted November 20, 2008 Posted November 20, 2008 Can you still use the fire alarm to signal class change or do you have to use something separate, or can it done a variation ? Thx Jim
sparky999 Posted November 20, 2008 Posted November 20, 2008 Can you still use the fire alarm to signal class change or do you have to use something separate, or can it done a variation ?Thx Jim Class change and the fire alarm should be two distinctly different sounds. Whether this is achieved by two different tones or two separate systems. Pete Peter Robinson Freelance M:07889038650
esp-protocol Posted November 21, 2008 Posted November 21, 2008 16.2.1 k) Fire alarm sounders should not be used for purposes other than warning of fire, unless the response required is identical to that required in the event of fire (i.e. immediate evacuation by use of all escape routes). However, as an established exception, the fire alarm signal may be used in schools to indicate start or finish of pre-determined periods. The duration of such signals should not exceed five seconds. ..... yes you can.
luggsey Posted November 21, 2008 Posted November 21, 2008 I used to maintain a fire alarm in a big school that had the door bell switched to the class change input in the holidays, the caretaker always heard the door bell!! ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
