What Panel Is This Please
Stewbow
Model number required
It's an addressable system
I think it's possibly Gents
The guy who ran PSA saddly passed away
Thanks for any help
May be a Gent Eurofire, a better pic of the buttons would help.
My Amateur Radio Forum
Thanks for any help
It is a Gent 800 series panel - Pete
I think the rest of the manual is in the manuals section. If not PM me and I will send you more info
4188_658_I1_1.pdf
Peter Robinson
Freelance
M:07889038650
The Gent 800 I installed was oblong shaped, I think it had some blue buttons as well. Did the make a 800 this shape??
One less nought then a 8000, which is oblong shaped! Dohh!
Thanks for the input
I can't find any info on the net re a Gent System 800 panel, is it no longer available?
if so what can I replace it with, without changing the other sytem componants?
some clown has just ripped this one off the wall and made a nice mess of the PCB :ranting:
I have never fitted an 800, what sort of devices are fitted to it, are they cone shaped or doughnut shaped. (MMMM doughnuts)
800 panel was same as a euro panel.
use conventional heads on addressable bases.
Not sure if its obsolete or not, however unless you are gent approved you won't be able to get the software to recomission a new panel
When the rep came round trying to flog the Euro we told him it wasn't going to be any good, every man and his dog was using combined detection-sounder wiring then Gent brought out the Euro with separate sounders, dohh!
Skippy were the bases for this the same as the "new" ones for the 2500?
Do you mean the 2400?
Detection that was used was the 178xx range otherwise known as xenex but with an addressable base.
Originally there was a thought that the 800 might have been a direct replacement for the 2400 but it never worked out like that
It does have a euoropanel sticker on the front and does have conventional heads on addressable bases.
Who can I speak to regarding this system?
thanks
