wbrells Posted November 24, 2008 Author Posted November 24, 2008 is it the same as a scantronic radio door contact you can hard wire a read switch to it but you have to move jumper on board to enable operation ?? The door sensor that I'm trying to modify is a SkyLink Door/Window Sensor model WD-101. It doesn't seem that much detailed technical info is available concerning this device. There is an internal jumper that is currently in position J1. Do you think that moving this jumper to position J2 will allow easier connection of an external reed relay? If so, where should the relay be connected? Thanks!
james.wilson Posted November 24, 2008 Posted November 24, 2008 from what i can see it doenst look as pro as a scanny one. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
