satsuma01 Posted November 25, 2008 Posted November 25, 2008 dpes anyome know why the new ethernet card sends packets of data no problem, and says connected to the router, 10/100mbps but does not recieve, is there something in the setup im missing. please gove us a bit of help as im baffled "If you carry your childhood with you, you never become old. Why rush to end life when happiness is in the blissfulness of childhood innocence.""We all die, the goal isn't to live forever, the goal is to create something that will." 07475071344
luggsey Posted November 25, 2008 Posted November 25, 2008 dpes anyome know why the new ethernet card sends packets of data no problem, and says connected to the router, 10/100mbps but does not recieve, is there something in the setup im missing.please gove us a bit of help as im baffled Check the security settings of the router? Reboot the router. Change the network cable and router port. Try a different PC with the same card. Have a cup of hot chocolate, go to bed. ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
Gopher Posted November 26, 2008 Posted November 26, 2008 check the settings are correct and that it has an IP and is set to auto full duplex might be a duff cable.. Intruder / CCTV / Access Control Technical Support Personal Subscriber to the "K.I.S.S" principle, that's Keep It Simple Stupid, are you?
james.wilson Posted November 26, 2008 Posted November 26, 2008 might also have the wrong address, or be set to dhcp with no dhcp server or address's available securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
