Honeywell Gen4 Accenta Mini With Lcd Keypad
finchee2000
Hi, I have just installed this system. On page 20 of the Engineers manual is Test Outputs. I've gone into this option via the LCD keypad in Engineers mode. When I go through each output, fire, PA, Intruder etc and toggle on/off nothing seems to happen. What is supposed to happen? Have I missed something?
(Before this I've done Alarm test on page 19 where you can check operation of Bell, Strobe and sounder no problem)
These are the comms output tests.
If youve got a speach dialler fitted you can trigger it via these tests without sounding the bells etc.
You wont need them if no dialler fitted.
