Optima 2 plus code
Guest timgrimes5
Guest timgrimes5
Just recently moved into a house with a Optima 2 plus system installed. When we power up, the alarm starts ringing. Does anyone know how I can reset the code.
Guest oldtimer
This panel has a Non Volitile Memory so even if you power it down it will always remember the last customer code so you need to speak to the last owner for the code.
The battery is probably u/s so you would best change it but first thing to do is get
the user code to see if the system is working.
If you do get the code then
Press prog enter original code press 8 then enter new code then press reset reset. Remember not to get distracted when doing this or you will have to crash the panel to return it to factory settings.
good luck
Guest timgrimes5
Thnks for that. Tried it, didn't work. Think I 've tampered with it too much and set it into permenant alarm. How do I crash the system as youve said pls.
Guest timgrimes5
How do I proceed from here? I live in Cambs (PE19) Will I need to call out an engineer. What do you guys think.
PS My daughter has just walked in with a box of chocs. Good girl
Just the alarm then thats leeting me down!!!
Unfortunately, it does sound like an engineer job!
There may be some people on the site who are near your area who can help.
D
Guest timgrimes5
Thxs Oldtimer
Thats done the trick.
All the zones are working and I,ve reset the acess code we can all remember. However the outside alarm is not working when the system is attacked. There was nothing connected to 40 /41. Is that why??
Shouldn`t 40/41 be the place where the backup battery is wired too..?
Is there a battery in the panel and is it connected..?
timgrimes5,
terminals39/40 are push to set, terminal41 set +VE latch, I think you need to check your bell wiring or bellbox ???
Clive.
