Accenta 8 Mini Tamper Lights On
ukteza
new to this site,its for my daughter,my wife put code in wrong 3 times now tamper light is on and key pad locked out,the alarm was going off for a while (daughters neighbours not to happy)then finally stopped ,strobes on bell box were flashing but stopped after long while,we only have code to turn alarm on/off and no manual any help much needed
by now you shoudl be able to enter the correct code and reset it.
thanks redbull tried it but keypad is locked out nothing happening
pressed reset still locked,thanks redbull,dont no default code as alarm was fitted before daughter moved in,only turn on /off code
