Voice And Sound Evacuation System
Hello,
There is large building - sport arena,
where according standards it's required
to design voice evacuation system.
I've visited some similar premises and I
noticed that there are lot's of fire alarm
indoor sirens (with beacon) - in halls, corridors, etc.
1. So, if in large public building there is voice
evacuation system is it required install fire
alarm sounders too? (not only according
standards but due to your practice too)
2. What working algorithm (typically) used
for activation both sound and voice systems?
Thank you.
If you are using a Voice Alarm System correctly designed to appropriate standards eg. 5839 pt 8 then there is no need to have fire alarm sounders as well.
The beacons may be installed as a staff alarm in such a large building to activate prior to the evacuation message being put out.
Hello,
Most PA fire systems I have worked on use the speakers as a fire alarm sounder between evacuation voice messages, to add extra sounders would be unnecessary.
Thank you.
Umm, I think you mean the order of events? In a large manned building normally a warning sounder for staff to hear on a delay before the system goes to voice evac.
My Amateur Radio Forum
Most Casinos we have done , voice is in public areas and standard sounders for back of house .
Two different fire signals in the same building? :'(
