MatonTE1 Posted December 17, 2008 Author Posted December 17, 2008 Just been looking at an 828m panel and I am using Fire 6.15 it says I can use a 3 way I/O unit.I haven`t got a 3 way I/O unit to try but I think you can use a 3 way on 828 Pete Hi Pete - It gives you the option okay but try and get it to give you access to use the three inputs (I had enough problems getting the three outputs to come up!). Morley say it can't be done under 828 but then that was "tech support"! Allen
luggsey Posted December 17, 2008 Posted December 17, 2008 Hi Pete - It gives you the option okay but try and get it to give you access to use the three inputs (I had enough problems getting the three outputs to come up!).Morley say it can't be done under 828 but then that was "tech support"! Allen The three ways still play up on newer software with Morleys, I had one that ignores inputs if another channel was an output, I could never resolve it so I ended up using a switch monitor as well.... Morleyyyyyyyyyyyyyyyyyy yyyyy y y y y y y y Arghhhh! ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum
MatonTE1 Posted December 17, 2008 Author Posted December 17, 2008 The three ways still play up on newer software with Morleys, I had one that ignores inputs if another channel was an output, I could never resolve it so I ended up using a switch monitor as well....Morleyyyyyyyyyyyyyyyyyy yyyyy y y y y y y y Arghhhh! They really are Point Of Sale items now,aren't they??
sparky999 Posted December 17, 2008 Posted December 17, 2008 They really are Point Of Sale items now,aren't they?? Sounds like Tech Support has moved back to the broom cupboard Peter Robinson Freelance M:07889038650
douglasdocherty Posted January 3, 2009 Posted January 3, 2009 From previous, I have found on FIRE 5, that it will see a 3 channel I/O, but will only operate a single channel output. All ok on FIRE 6 tho AWACS UK Website email: advanced warning and communicated systems installation...intergration...innovation
MatonTE1 Posted January 3, 2009 Author Posted January 3, 2009 From previous, I have found on FIRE 5, that it will see a 3 channel I/O, but will only operate a single channel output. All ok on FIRE 6 tho Takes a bit of feckin about but I can get the three outputs okay. In this case it's the seperate inputs that are an issue on firmware 828 and below (according to Morley). However,will be using a lot less of them from now on and this is just one example of why.
