Galaxy 2-20/dt7550a
DaleR
is the sensor square on to the door, or is it in the corner?
Corner mate, and yes 100% on minimum. It's fine when PIR isnt triggered obviously, but bit of a pain if I trig the pir on exit, 60 sec on exit doing the trick at the moment, but if someone hangs around a bit longer then leaves it might pose a problem. The other thing I had in mind was using one of the outputs on the trigger header, setting it to power up on arm, but that detector takes ages to initialise on start up, also not sure if it triggers at some point during start up.
yeah dont be powering it down like that.
i think your only option is to move it.
You may try moving the sensor left or right as the mic on the horn is more powerful just at the edges, so a small treak into the wall may help you.
nope not if its activating quickly
one thing might work
put the dt on slow zone response and the door on fast
