Door Bell
Wot can i program a zone up as to use for a doorbell on a scantronic and menvier?
Heard someone suggest it ages ago but havent got any manuals to hand to have a browse! cheers
24 Hr cct with chime enabled ?
or is that against someones regs and too easy ?
Ahh, but then you would get full alarm with system set! (though could omit that zone each time you set system)
On a recent scanny could use tech alarm for pulsed tone from keypad when unset & nothing when set, but alert that doorbell pushed whilst you was out.
PITA IMO.
Won't that give an internal alarm when unset and a full alarm when set?
:unsure:
Bugger, Potter beat me again!
Curses!!
My Amateur Radio Forum
:unsure:
Curses!!
I'm a bit out of touch but I seem to remember you could program a zone as ET (exit terminate) and program it as chime on some panels.
24 hour is definately not the way to go!
Agreed. Would be helpful if you (samnaffy) could tell us what panel
I have a doorbell on my alarm, I put the zone in it's own ward and inverted the zone, works well.
I suppose you an only do it on a panel with wards/groups etc?
PITA IMO.
Asoluely right........my mind was elsewhere !
I did it with a menv once, obviously not 24hr alarm, though
