Door Bell
On a 9751 you cant prog an ET button as doorbell. You might be able to mess about and either set cct on own partition as luggsey suggests or use tech alarm as I posted above - then you would have to acknowlege alerts each time!
Dont know about the TS, tbo i've never tried to use any alarm as a doorbell.
Hi, Thanks for your posts. Its a menvier ts690 but also would like to know for a scanny 9751! Thanks.
No problem for the TS690. You can programme a zone as 'auxiliary' this will just monitor the circuit and not activate an alarm and the chime can be enabled. You will even get a log report of when someone came to visit!
Just remember the wiring method will need to be as if it was just another detector.
There is no option like this with the 9751.
