madkad Posted December 30, 2008 Author Share Posted December 30, 2008 Next try a LAN crossover cable, Maplins sell them.Do a web search for the instructions and software, you will need to know the URL of the DVR (It's IP number) which should be standard. are right just looking it might allready be a cross over cable, it says on it CAT5 UTP it was a cable I had left over from a router what would it be called for a nomle cable? thanks for your help also Link to comment Share on other sites More sharing options...
james.wilson Posted December 30, 2008 Share Posted December 30, 2008 it may not be marked in either case. If you plug them in do the lights on the posts come on. If not and you going port to port (ie no switch or hub) then its isnt a cross over cable. You will also need to set ip address's on each peice of equipment. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Pedders Posted December 30, 2008 Share Posted December 30, 2008 This link may give you a bit more help on the matter Linky Pete Bennett Northern CCTV Services T: 0845 838 7383 E: info@northern-cctv.co.uk www.northern-cctv.co.uk Link to comment Share on other sites More sharing options...
madkad Posted December 30, 2008 Author Share Posted December 30, 2008 ~ Thanks for the link i looked at that before, I allready have the software it came on a cd, its no good as I need to be able to conect first with my lan ether other the router (cable to that is very far) or to my pc witch is right next to the DVR, I could phone the number on the thread it may not be marked in either case.If you plug them in do the lights on the posts come on. If not and you going port to port (ie no switch or hub) then its isnt a cross over cable. You will also need to set ip address's on each peice of equipment. I think I know what you meen, there doesnt seem to be any lights on, the local erea conection just says no cable plugged in, I have added the ip address of my DVR but still the same. so do I need the lights to come on? this thing is confusing me Link to comment Share on other sites More sharing options...
Pedders Posted December 30, 2008 Share Posted December 30, 2008 Check Here to see if you definately have a crossover cable or straight through. I would have thought if you have a cable that came with your router it would be straight. Pete Bennett Northern CCTV Services T: 0845 838 7383 E: info@northern-cctv.co.uk www.northern-cctv.co.uk Link to comment Share on other sites More sharing options...
madkad Posted December 30, 2008 Author Share Posted December 30, 2008 Check Here to see if you definately have a crossover cable or straight through. I would have thought if you have a cable that came with your router it would be straight. nice one thanks for that, looking at it my wire is both the same as diagram B so its not a crossover. so I take it my local erea conection is playing up and I need to fix the setup some how to get it to work Link to comment Share on other sites More sharing options...
