Accenta8 To Reson8 With Only 4 Wires ?
tonywye
Hi,
I have a new Accenta 8 and Reson8 bellbox but only have 4 wires available to connect them together (cable already run in by the builder). The manual says you need 5 wires. At the moment the strobe is not working since thats the one wire I decided not to wire up. Is there a way to get the strobe to work when the siren goes off or something (maybe wiring two of the terminals together on the Reson8 ?).
Thanks , Tony
  tonywye said:
Hi,
Thanks , Tony
Yes it's easy. I don't know what the terminals are called in your sounder but just link the strobe trigger to the sounder trigger in the sounder.
