Guest tobyben Posted July 1, 2003 Posted July 1, 2003 Would like to know if anyone has an Installation Manual for the Microtec 2000 Panel made by ITECSecurity Products.
mr silcox Posted July 2, 2003 Posted July 2, 2003 got one some where ????? is there something in particular you need to know???? :?:
Guest tobyben Posted July 5, 2003 Posted July 5, 2003 Thanks for replying. I need to know how to enter "engineer mode". I need to change the Operator Code as it is for a house move. I think you need to enter 4.4 {New Code} *, the problem is how to get into engineer mode. I think I have the code number and when entered it shows "-" on the display, but how then do you enter the 4.4 every time I press 4 it shows 4. not 4.4 If you can help it would be great. Thanks again
mr silcox Posted July 5, 2003 Posted July 5, 2003 ok first if your getting the "-" on the display your in engnerring mode then you must open the lid of the panel this will allow you to continue with the programing then put in 44 then your new code (can be 4 to 6 digits long but you can not use a "0"zero ) then the star key (*) a square box (or small 0) will apear thats it done close the panel then go 0 then star * if you feel very brave use the same as above but use 45 and that will change the engineering code good luck
Guest tobyben Posted July 6, 2003 Posted July 6, 2003 Top Man Thanks a lot for your help. It worked first time. The problem I had was I had the panel open when I entered engineer mode. Thanks very much, another satisfied customer
