Guest p3glr Posted June 22, 2004 Posted June 22, 2004 I recently had a power cut and ever since the keypad on my Accenta G3 (RKP) appears to be dead. Power (13Volts) is being supplied to the terminals and the keypad is illuminated but the power, zone and day LEDs are not illuminated.Entering the engineering or user code does nothing either . The alarm system was fuctioning before the recent power cut and has work fine after others. A new keypad only costs around 20 quid but I would like to make sure it really is broken before replacing it. Any help would be very much appreciated/ Thanks
Guest p3glr Posted June 22, 2004 Posted June 22, 2004 I hope it doesnt need a service - I only moved in 4 months ago! Ive also checkd the battery in isolation - 13Volts. Ive also checked that power is being suplied to the keypad - it is! Is it normal for the keys to be illumianted but not the power led ?
