9448+ Locked Out After Power Cut
russandsu
Hello,
had a power cut tonight alarm went off during which I expected, but now power is back on the white light is flashing on the outside box. The keypad is not letting me input my code - seems like it has timed out. Rang company who said that could be a blown fuse - I can get hold of 1A fuses, but how do I access the unit without it ringing all bells - thinking I am tampering with it? thanks for any suggestions... :rolleyes:
you cant, if its set then it will activate the bell when you touch it. If it isnt then the internals will go.
If its on a contract then id call them back and say you need an engineer
thanks for quick response...appreciated
there is no internal fuses on a scantronic panel and it is likely your standby battery is depleted and your panel has defaulted back to factory default settings and that is why your code does nothing,
9448+ has 3 internal fuses IIRC, AC, 12v Aux and Battery.
QFA
QFA
:yes:
lol, ADT at its finest
