jasonadt Posted December 30, 2008 Posted December 30, 2008 hello first time i've come across this one gardtec800, anyone got a user and engineer manual, system needs a reset and the system is a bells only, therfore should already be set up for customer reset, plus how do you reset engineers code and manager code if anyone can help, be much appreciated, jay.
james.wilson Posted December 30, 2008 Posted December 30, 2008 your not gonna get this info on the public side jason for security reasons. Once your post count is higher and you can prove your trade it might be worth putting an application in. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
lawandorder Posted December 30, 2008 Posted December 30, 2008 hello first time i've come across this one gardtec800, anyone got a user and engineer manual, system needs a reset and the system is a bells only, therfore should already be set up for customer reset, plus how do you reset engineers code and manager code if anyone can help, be much appreciated, jay. To reset the system all you have to do is enter the user code, start the setting procedure then unset again.
chexsec Posted January 17, 2009 Posted January 17, 2009 There are various programmable reset options:- User, Engineer or Anti-code. If the reset is programmed for Engineer then the engineer code may be locked which requires reset by the manufacturer. If the engineer code is not locked an accomplished engineer should be able to work out how to default it.
alterEGO Posted January 17, 2009 Posted January 17, 2009 If the reset is programmed for Engineer then the engineer code may be locked which requires reset by the manufacturer. Or by us
