Wiring Cqr Soint" (internal Sounder) To Accenta G4
lesliez
I need to wire a CQR internal sounder (model SOINT2) to my Accenta G4 Panel. The sounder has a tamper switch and an LED. There are 5 connections on the sounder which are:
+12V
Trig
-LED
A/T
A/T
I presume the +12V from the sounder goes to the +12V on the panel
The Trig is connected to the B connection on the panel (which is where the sounder connection goes to from the Odyssey 5 bell)
The -LED is connected to the Set connection on the panel.
Both A/Ts go to the tamper circuit (wired in series).
I would be grateful if someone could confirm if the above is ok.
Not sure what you mean. The Trig will be connected to output B on the panel, which is the out put for the bell. Can you clarify please?
you need to put the -LED in the B connection so that the led (strobe) comes on with the bell. or if the LED is to be used as a comfort light then ust put the -LED in -12v
Eucam Security Systems
0845 4630 746
www.eucam.co.uk
