Honeywell Domonial Or Bosch Easy Serie (wireless)
Hi,
I am looking to equip my 3 bed-houses-end of terrace with a wireless alarm system. After lots of research, I came to the conclusion that the Domonial honeywell or the Bosch easy serie would be adequate: I need an international brand wireless system, with keyfobs, text messages, built-in sounder, PIRs and door contact sensors .
Would you know which one of the two system is the most reliable or has the best price to quality ratio?
Thank you
From my experience easi series and dominial have had some problems
Try the i-on16 from Scantronic ... i've fitted lots of these they are so easy to fit & use it almost makes you feel that you have left something out, the radio frequecy is narrowband on narrowband (not wideband like the promax, etc...) the most secure frequency on 868
The speechdialler plugs on in seconds and has a broadband filter option ... you can get text via intermac monitoring service only but speechdialler will call you and has a digi on it too
The signal strength can be measured on the panel ensuring a healthy install - you cannot cross enrol devices onto the same circuit either its rfid
If you want reliablity and quality go for the i-on16 try this link www.i-on16.co.uk its an online demo ... saves a visit from a rep
You won't even need the manual and the range is unbelieveable
Good luck !
Good luck !
I've just started fitting these, I got a demo before christmas and the feedback on here seemed positive.
Quickest install i have done on a domestic + I chanced my arm and have been adding
