Patio door sensor
Guest gpgp
Guest gpgp
We are having our patio door replaced with french windows soon(uPVC). The patio door has a sensor on it.
This will need to be changed to a different type of sensor I assume.
My questions are
1) Is this a DIY job or do I need to call out the engineer?
2) How much can I expect to pay to have it done?
3) Should the work be done before after or during the installation of the door?
The system is a TS410
Any advice would be gratefully received
Guest THOMSONSECURITY
Well The sensor will have to be removed before the new patio door works are carried out, then either a new sensor (favorite idea) fitted or the old one re fitted (Cheapskate idea) once the door works are complete
Question is do you have the necessary skills to do the work?
If not its man in a van time :red:
