Galaxy G2-44
SydoIT
Hi All - I wonder is anyone can shed any light on an issue were having with SMS and a Galaxy G2-44 panel with a GSM unit ?
We currently have installed a G2-44 Comms, control panel and cannot get the thing to text message at all, we have the GSM unit installed with an o2 PAYG sim and have configured the following options
56 - 5(GSM) -17 (SMS Paging)
1 - Mobile Numbers ( we have three numbers in here two set to Alarm & Fault Condition 1 Set to Alarm only)
2 - Center Number We have tried three different numbers in here 00447802000332, 00447802092035 & 00447958879889
3 - Format TAP (Default)
4 - Site ID (a text string)
5 - UCP Operation 3 SMS Message
We have also set the hardware prority to be off for telecomes and on for GSM
We have also checked Menu 60 Option 61 and the signal level is at full.
When we reset the control panel and force an alarm condition we get SMS Comms Fail with any of the settings ?
Can anybody give a definative step by step guide to getting this working corectly ?
Also, we could do with knowing how to get hold of the remote servicing software for this alarm :whistle: - is it only available direct from Honeywell ?
Thanks in advance
Neil
Sydo Security Services.
Guest RJBsec
2. Format 07958879889
RSS Software via your local rep or from Honeywell.
Sorry dont do Galaxy, (sure them guys will be online in a while).
Mentioned credit as (royal) we have overlooked ourselves on sites.
I once had a GSM unit on a Premier that the PIN code request was turned on for the sim, put it in a phone, turned off PIN, et voila.
I doubt thats your problem if you've dialled out on a phone with the sim.
