RichardAirey Posted January 10, 2009 Posted January 10, 2009 Dear Friends, My current alarm panel is over 20 years old and I have decided enough is enough I have decided to go for a veritas R8. The panel is located in the hallway about 3 meters from the front entry, shoulder height in clear view. Since relocation will cost alot more instead I wish to mount the R8 main box high enough so that a ladder is needed MY QUESTION: To do this I would need to extended some wires to reach the raised box, how would I go about hiding the Terminal blocks which are at shoulder level? Is there a smaller alternative to using terminal blocks? Thanks is advance!
hpotter Posted January 10, 2009 Posted January 10, 2009 Not wishing to put you off upgrading, but I'd be inclined to start again. New panel, detectors & wiring (as you wish to resite the panel). Additional cost would be minimal - click the sponsor link above for prices. If you must do junctions I'd solder joint & heatshrink sleaving.
james.wilson Posted January 10, 2009 Posted January 10, 2009 Quote If you must do junctions I'd solder joint & heatshrink sleaving. qfa securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
goncall Posted January 10, 2009 Posted January 10, 2009 RichardAirey said: Dear Friends,My current alarm panel is over 20 years old and I have decided enough is enough I have decided to go for a veritas R8. The panel is located in the hallway about 3 meters from the front entry, shoulder height in clear view. Since relocation will cost alot more instead I wish to mount the R8 main box high enough so that a ladder is needed MY QUESTION: To do this I would need to extended some wires to reach the raised box, how would I go about hiding the Terminal blocks which are at shoulder level? Is there a smaller alternative to using terminal blocks? Thanks is advance! or just replace it with a new panel with onboard keypad that looks ok in the hallway
Rulland Posted January 10, 2009 Posted January 10, 2009 goncall said: replace it with a new panel with onboard keypad that looks ok in the hallway Ensuring that it conforms to EN 50131-1 as well then ?.
A-G Posted January 10, 2009 Posted January 10, 2009 Rulland said: Ensuring that it conforms to EN 50131-1 as well then ?. No . . . PM me for access to the SSAIB members discussion area.
goncall Posted January 10, 2009 Posted January 10, 2009 Rulland said: Ensuring that it conforms to EN 50131-1 as well then ?. if its a diy then no need.yale do some decent looking kit aimed at the diy market.with some good looking features,never used them but they look ok on first view
james.wilson Posted January 12, 2009 Posted January 12, 2009 there are en panels with onboard keypad. Isnt the veritas Compact Grade 1? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
