SaxmanUK Posted January 10, 2009 Posted January 10, 2009 Hello All Complete Newbie here Many Thanks for you help in advance. When I set my alarm I have the message PIR 004 SUN ROOM active. I presume the PIR has gone closed, or open circiut, which ever way round these things work! Before I rush off and buy a replacement PIR for the Conservatory (Sun Room) would there be any other simple things to diagonose the problem? I have tried setting the PIR on all settings i.e. pet, standaed etc Sean
camerabloke Posted January 10, 2009 Posted January 10, 2009 is there any power on it first off? Eucam Security Systems 0845 4630 746 www.eucam.co.uk
SaxmanUK Posted January 10, 2009 Author Posted January 10, 2009 is there any power on it first off? Many thanks for replying Yes just tested 13vDC on power in have cleaned terminals PIR led flashes 3 times when put back into backplate - then no led when you move hand across sensor Sean
SaxmanUK Posted January 10, 2009 Author Posted January 10, 2009 I have changed the dip swithches to 1 = low 2+ 3 tp pet avoid there is no led flashing at all
lawandorder Posted January 10, 2009 Posted January 10, 2009 I have changed the dip swithches to 1 = low 2+ 3 tp pet avoid there is no led flashing at all If you have power to it and there is no walk test LED then yes, replace the detector.
secur4u09 Posted January 12, 2009 Posted January 12, 2009 The relay sounds faulty mate in the pir might be worth swapping it over for a replacment and see if you have the same problems or order a replacement pcb for the pir
