lesliez Posted January 10, 2009 Posted January 10, 2009 Hi If I enter the enginneer code on my alarm (Accenta G4) can I remove the panel cover without the alarm sounding. The reason for asking is that I want to add an internal sounder. Thanks
lawandorder Posted January 10, 2009 Posted January 10, 2009 HiIf I enter the enginneer code on my alarm (Accenta G4) can I remove the panel cover without the alarm sounding. The reason for asking is that I want to add an internal sounder. Thanks Yes if you enter engineer mode you can remove the cover from most devices without causing a tamper condition.
lesliez Posted January 10, 2009 Author Posted January 10, 2009 Yes if you enter engineer mode you can remove the cover from most devices without causing a tamper condition. Just what I thought but I just wanted to be sure. Thanks for your reply.
