RichardAirey Posted January 10, 2009 Posted January 10, 2009 Dear Friends, Does anyone have a clue on how flashing led's (drill hole and put flashing wire ended LED's) on the bell box are wired to the control panel on a veritas R8? all I can think of on the control panel.. is bell output,strobe output Many Thanks
Chorlton Posted January 10, 2009 Posted January 10, 2009 If this is the same panel as here - http://www.thesecurityinstaller.co.uk/comm...c=26239&hl= the same advice applies
Rulland Posted January 10, 2009 Posted January 10, 2009 Hi, The flashing LEDS are built into the external sounder, just connect sounder up to the panel as required and thats it. (obviously you will need a sounder with the LEDS in-to retrofit is false economy).
magpye Posted January 10, 2009 Posted January 10, 2009 Dear Friends,Does anyone have a clue on how flashing led's (drill hole and put flashing wire ended LED's) on the bell box are wired to the control panel on a veritas R8? all I can think of on the control panel.. is bell output,strobe output Many Thanks I suspect you mean the 'add on ' type you can get from Fleabay etc, if they are run from a 9v Battery, yse that, if 12v is required get it from the 12v Hold off in the Bell box, they will then flash for ...................................................... & longer Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
RichardAirey Posted January 10, 2009 Author Posted January 10, 2009 Thanks for all your replies. Magpye your suspicion was correct, thanks for the advice. Great generous people in this forum Richard.
