Xr2 Citadel (no Power To Panel) Help Please
needy
Hi all
I have just moved my key pad from the bedroom wall to the landing (just drilled through the wall to the other side),I labled all the wires before i disconected them so they went back in the same place.
I have now mounted the box on the landing put all the wires back and there is no power to the key pad,also the downstairs key pad is dead (and i havent touched that) also the lights are flashing on the box outside.........i do have power to the main alarm box.
Can somebady please help me solve this problem as the wife is going nuts with me
Its a Xr2 Citadel
Thanks
Tony
you have blown the aux fuse inside the panel. you will need to open it up and replace like for like, probably 1.6A quick blow glass fuse. be careful as mains voltage will be present
Eucam Security Systems
0845 4630 746
www.eucam.co.uk
Just had a look at the fuse and it looks fine.............what else could it be..............any ideas
have you actually tested with a multimeter?
07475071344
