cadgey Posted January 12, 2009 Posted January 12, 2009 Hi Having installed the G2-20 over a year ago, installing CCTV and extra locks, we still got broken into while away over xmas by someone throwing a brick through a window! The alarm triggered and reset & triggered over 3 hours (who knows what he was doing in the house for that long!) until a neighbour finally investigated. I want to set the system up to text me, as we would have known what was going on, and I thought I had it worked out! I plugged a phone cable (from a laptop) into the onboard socket, programmed in a Vodafone sms centre and tried it - but it gave me an sms comms fail. I have a number of questions, some of which may be stupid, or irrelevant, but all help appreciated! 1) Is the socket the easiest way to connect - I realise there is a header as well, but as I had a cable ..... 2) I am using the following SMS Service Centre: Service Provider: Vodafone TAP Message type....: SMS Access number...: 07785499993 (Modem) Comm settings...: 8N1 Text length.....: 160 Max messages....: 2 Smart Messaging.: No I am assuming that I just dial to this, and they make their money through me dialling their 07xxx number - is this right? 3) The service centre uses a modem format of 8N1 - and from my old days of modems I remember having to set this in an init string - but I can't see how this is set, or what format it might use on the G2-20. Any help or advice would be much appreciated. I wish I had gone for the G2-44 now which supports a GSM module ..... but too late now! Chris
Pandysec Posted January 16, 2009 Posted January 16, 2009 Why are you connecting it to the outside dialer socket? just connect a normal 50v telephone line a and b on the pcb, and program the settings in the test option under comms, 56, then sms. Its much easier, just program up centre number, but the one i use always works and was supplied by a tech support ages ago, and bingo instant messaging, just be careful as it has the tendency to text for one alarm activation around 3-4 times. Andy
timtimmo Posted January 22, 2009 Posted January 22, 2009 Why are you connecting it to the outside dialer socket? just connect a normal 50v telephone line a and b on the pcb, and program the settings in the test option under comms, 56, then sms.Its much easier, just program up centre number, but the one i use always works and was supplied by a tech support ages ago, and bingo instant messaging, just be careful as it has the tendency to text for one alarm activation around 3-4 times. Andy Hi, Sorry to interupt this post but I too am trying to get SMS text working..... what is this centre No. business????? Thanks in advance - Mark
