zs123 Posted January 13, 2009 Posted January 13, 2009 Hi im looking for a camera to cover a 15m driveway, that has a 150w floodlight. can anyone advise if it is better to get one with IR or one without that switches toB&W and has sens up with auto iris control? Camera 1 1/3" Sony CCD 420TV lines 0.1lux @ f1.2 Switchable on/off Auto Gain Control Switchable on/off Auto white balance Electronic Shutter (up to 1/100,000sec linear) Switchable on/off Automatic Back light compensation 6mm lens with Electronic Iris Control 12v DC 800mA | UK power supply included Camera 2 30 InfraRed LED | 30 meter range 1/4" Sharp CCD 420TV lines 0lux @ f1.2 (IR on) Auto Gain Control Auto white balance Electronic Shutter (up to 1/100,000sec linear) Automatic Back light compensation 6mm lens 12v DC 800mA | UK power supply included relaise there not the best specs but its only ahome system and cant afford more at the moment so any advice on which would be best suited is gratefully received
Neutech Posted January 14, 2009 Posted January 14, 2009 Neither to be honest you have a security light so forget IR onboard unless you fancy cleaning spiders webs off it every few days 520 / 540 TVL and go for varifocal so at least you can set the lens to where you want to see, Cut filter not as expensive as you think and better picture Quality
zs123 Posted January 14, 2009 Author Posted January 14, 2009 Neither to be honest you have a security light so forget IR onboard unless you fancy cleaning spiders webs off it every few days 520 / 540 TVL and go for varifocal so at least you can set the lens to where you want to see, Cut filter not as expensive as you think and better picture Quality oh ok, do you have any links to a camera of the spec you mention that wont beak the bank?
james.wilson Posted January 14, 2009 Posted January 14, 2009 also id strongly advise against comparing specs alone. I have seen many a med res high quality brand give a far higher quality than a so called 540tvl 'SONY' chipped cheap camera. I have an intel processor in my main pc but the rest of its cheap sh!te..... i is it an intel PC?.... if you see what i mean securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Matt the Teckie Posted January 16, 2009 Posted January 16, 2009 If you have problems with Spiders, there's some cracking kit from QED that repels them. Check out www.spiderex.co.uk Matt
