Justin Roberts Posted January 15, 2009 Posted January 15, 2009 I ahve recently had trouble with a Informa speech diller. When i programme a number into phone number 1 and test using the test function does not dial number 1 if i put the same number into phone number 2 it will test and goes through fine. What ever number is programmed into number 1 does not work at all. Has anyone had this same problem or does anyone have the answer to this wierd fault. ?? Thanks for your time
Alarm Co Posted January 15, 2009 Posted January 15, 2009 I ahve recently had trouble with a Informa speech diller. When i programme a number into phone number 1 and test using the test function does not dial number 1 if i put the same number into phone number 2 it will test and goes through fine. What ever number is programmed into number 1 does not work at all. Has anyone had this same problem or does anyone have the answer to this wierd fault. ?? Thanks for your time have you tried testing normally by triggering alarm? sounds like force dialling phone number 2 by default maybe??
Justin Roberts Posted January 15, 2009 Author Posted January 15, 2009 Yes thay have we have tryed setting and triggering an alarm. I there a setting where you can disable the tel numbers at all?? I do not have a manual on this speech dialler at all.
Baracus Posted January 22, 2009 Posted January 22, 2009 I was having a bit of bother with one of these tonight, when I trigger the input or try a test call it dials the number fine but the message starts too early and by the time the recipient picks up the call the message is halfway through. Surely there is some way round thins? I cant see a delay setting anywhere in the manual. (And yes I know it is a piece of c##p!!)
Justin Roberts Posted February 2, 2009 Author Posted February 2, 2009 I usually use use menvier sd1 speech diallers so dont no much about these speech diallers. It cnt b anythin to do wid when you speak and record the message. Maybe has something to do wid what message is assigned to what output, Is there 2 types of message ? 1 for the site name and 1 for the alarm activation details? Best thing is probably to just read through the manual on a sunday afternoon haha or default and try again bud !!
