Ademco Accord Transformer's
Hi, just wondering if there was anywhere that would be able to supply ademco accord transformers?
The company I work for used the panels up untill a couple of years ago, an roughly every month we get one or two panel changes due to these burning out.
Thanks
they are torture to deal with, stopped using them completely after they //.B.W.F.// us about with the panels, do you know of any similar transformers that could be used in its place?
its the same one as used in the galaxy 16,remove the metal casing on the t/f that the 16 uses to fix it to the panel and its the same t/f,failing that try RS components
