housty Posted June 25, 2004 Posted June 25, 2004 Hi all A customer want's a static camera looking at his property with a zoom lens so he can zoom into cars waiting at his barrier. I know i have to run power to it (240v) and also RG59 but what sort of cable do i use to control his zoom??Is there any other way of doing it?? He has an exsisting telemetry system would i be able to tap into it for control of the zoom?? housty Houston Security Systems Ltd Intruder alarms CCTV Door entry Fire protection Networking SSAIB Approved
CompostCORNER Posted June 25, 2004 Posted June 25, 2004 Firstly, you would need a suitable data transmission cable in order to send telemetry to the camera or lens from the controller. 'Up the Coax' is easiest where the signal is encoded, sent down the same coax as the picture, and decoded at the camera. Twisted Pair telemetry is the better for longer distances but would require the camera/lens to be addressed by a unique identity different to other units on the system, in order that the equipment recieves the correct instructions meant for it. Secondly, theres many different types of telemetry protocol. Is the manufacturer the same for all the CCTV units on the system? camera, controller ect... You cannot mix equipment from different manufacturers unless the product supports the telemetry protocol in use. In a similar way that you cannot use a PC game on a Amiga 1200. Somehow, I sense you thought you could just splice into the existing system with realative ease. Tony
CompostCORNER Posted June 25, 2004 Posted June 25, 2004 You'll probably find that the zoom lens is powered by 9vdc too. Also besides the zoom, you'll need focus capabilities otherwise your pics will blur as you run the zoom.
housty Posted June 27, 2004 Author Posted June 27, 2004 Hi all So it would be easier if i gave him a separate controler just for his zoom?? Also would i need twisted pair cable (screened or unscreened??) with a transmitter at the lense and a recieiver at the controler and RG59 for video back to the multiplexer?? Houston Security Systems Ltd Intruder alarms CCTV Door entry Fire protection Networking SSAIB Approved
housty Posted June 27, 2004 Author Posted June 27, 2004 "Up the Coax' is easiest where the signal is encoded, sent down the same coax as the picture, and decoded at the camera." How is it done?? "you'll need focus capabilities otherwise your pics will blur as you run the zoom" Would the lense need auto focus?? Houston Security Systems Ltd Intruder alarms CCTV Door entry Fire protection Networking SSAIB Approved
Guest stevevtec Posted July 17, 2004 Posted July 17, 2004 Hi guys The simple solution with this is to run an alarm cable along the same route as the coax and drive the lens using a couple of dpdc spring return switches, a 12v (or less) psu. Also if the lens is of a reasonable quality and the backfocus (or racking) is set correctly then the focus shouldn't need adjustment. Steve
Guest cctvman Posted July 24, 2004 Posted July 24, 2004 As steve says an alarm cable. 12volt lens ie red/black for zoom 12+ red 12v- black applied for zoom in red/black for zoom 12 - red 12v- black applied for zoom out the same for focus Use a two pole switch or relay if you have any problems i can send you a drawing Regards Cctvman
norman Posted July 25, 2004 Posted July 25, 2004 As said above Nothing is foolproof to a sufficiently talented fool.
