Mag Locks For Fire Retaining Doors....
I need to fit Mag Locks to a set of Fire retaining doors, but can't drill the doors...
Any suggestions????
Any reason why not??
Nails? :o
My Amateur Radio Forum
Is it that you cant drill through the doors ?
If you can screw to the doors, could you use use armature plate housings.
or is that too easy ?
should mag locks be fitted to fire doors????
Why not, fire doors are required to be closed at all times, as long as there is relay release on fire signal thats fine, most mag locks fail open anyway.
Bri
so the only time you can fit to a fire door you must conect alarm panel to fire alarm,
Surely that goes for any door, as long as security isnt compromised.
but thats not for a public forum. ... in my humble anyway.
