Drilling A Hole For A Phone Cable
Compuclick
not sure if am posting in the right place here,
I live in a cottage its got walls about 1m thick so drilling thu the wall to put a phone cable outside is gonna be really hard. i have double glaze windows and wanted to know is it possible to drill in to the plastic frame at all?
If this is possible where is possible to drill?
Thanks
Dave
Drilling through the frame will make it prone to leaking. I really wouldn't advise it. What about drilling near the frame on the inside on an angle through to the outside wall. Should reduce the length a little.
Trade Member
Is this a stupid answer ? why dont you bye a long drill bit and drill the wall in the right place. Qvc electrical sell them in a pack of three 1.5m long bits for about
TVX systems what a good idea by the time the picture had downloaded the intruder would have been long gone.
SFE.Solutions security systems
Drill next to the vertical frame at the bottom into the wall at about 45 degrees, don't drill into the frame! Then go to the other face of the window and drill a matching hole to meet up with the one you just drilled. You will need about a 10mm masonry drill for this. Feed cable through hole, fix cable, then stop up hole inside with painters mate/filler. Fill hole outside with silicone. Job done.
If you drill an old cottage wall i metre thick you will usually find small bits of cob/stone fall into the hole as soon as the drill is removed, these can jam the cable as you pull it in, unless of course you drill a much bigger hole!
In my part of the country I have drilled loads of 'mud huts' external walls for external sounders and sometimes it can be a nightmare! ;)
My Amateur Radio Forum
To get round that problem in the past I've left the drill in the hole, releasing the chuck and taking it away, then taped a thickish string carefully (end-to-end) to the driven end of the drill before puling it through from the other side.
It usually works OK as the business end of a masonry drill is larger than the shaft.
Just get a meter bit and have done with it, you've got one for next time then and won't have to worry about shafting up the window..... I wouldn't drill a pvc window in a million years and it would take the earth for me to drill through a wooden one come to that!!!
CCTV Intruder Access Control
Tony Hughes, Proprietor,
TRADE MEMBER
