quickquestion Posted January 20, 2009 Posted January 20, 2009 Hello guys Do you think external GJD OPAL XL pirs gonna work properly if theres IR LED camera fitted above each of them? is it the same frequency infra red wave? regards Adam
SUBS Posted January 20, 2009 Posted January 20, 2009 Cant see the lamps causing a problem. I can see your point, but we used to fit PTZ Cameras with a pair of 500W IR lamps that moved around all of the time without having any effect on Opal Elites or on any other PIRs as far as I know. so I cant imagine a few IR LEDs making a difference. Only thing with those PIRs was that IMHO you never seemed to get the range that GJD claimed unless you had the front cover off.
