Veritas 8C Control Panel
Guest itjob
Guest itjob
Hi,
I have a Veritas 8C control panel. I recently went through a system check and found that the bell box sounded when I removed the 3am Fuse within the fuse spur.
The panel lost all its settings reverting back to the factory settings.
I assumed that the back up battery must have been faulty so I bought a new one.
I have installed a new battery and checked the wiring contacts but if I remove mains power the bell box sounds off.
Any Ideas????
Most modern panels have in built circuitry that auto disconnects the battery from the panel when it becomes faulty to avoid damage to the alarm equipment. Some Scantronic panels use this and can catch people out if it doesn't reset once a new battery is installed. I doubt it's this as usually a full power down of the system restores this. More than likely, the battery on your panel is connected to a circuit that incorporates a glass fuse. This most certainly would have blown if the battery started pulling a large load from the panel whilst it was failing. Changing the internal glass fuse is not something I'd recommend doing unless you are confident and competent to do such things. It's of course at your risk but i would suggest calling a local alarm installation company to fit a new fuse as they would also check that the battery failure hasn't been caused by some other underlying problem. Best be safe than sorry is the best principal.
Also, your panel should not revert to factory settings when power is lost as it should be equipped with a 'non volatile memory' chip. This stores all engineer programmed variables the alarm needs to work correctly in the premises it's installed in. Again, another reason why I'd suggest a visit from a reputable alarm company. your alarm panel may be suffering a slow death and may be in need of a replacement.
Tony
  • 4 weeks later...
Guest itjob
Tony
16228[/snapback]
Guest itjob
Tony,
Many thanks for the quick reply which I have only just read due to holidays. I will have the unit checked out as suggested.
Thanks again for the help
Regards
Itjob
  • 2 months later...
I was wondering what to do with my Veritas 8c as I have just moved into a new property and the previous owner does not have the code available. Is it possible to aquire the instructions from anywhere and reset it to ny own code?
