engltayl Posted January 24, 2009 Posted January 24, 2009 Hi, I have a Veritas R8 Alarm system and have a problem or two? The internal buzzer sounds randomly and shows a tamper fault on the keypad LED. Whilst trying to find the fault I checked the main panel and it seemed that F2 fuse (bell & strobe) was blown. I replaced this and after a few hours/days it blew again. I have also replaced the battery recently. It seems that the 2-off movement sensor also dont work after the fuse has blown. I am wondering what steps to take to isolate the problem, i have full access control to the panel. My other option whould be to rip it out and install a new system. Any help would be much appiciated. Thanks
A-G Posted January 24, 2009 Posted January 24, 2009 Want the cheapest option? Call in an alarm company with experience of the Veritas panels. They'll be able to identify the fault(s) & offer rectification. . . . PM me for access to the SSAIB members discussion area.
engltayl Posted January 25, 2009 Author Posted January 25, 2009 No carpets, But most of the cabling runs up to the loft and then down the walls to the sensors or keypad. I'm wondering if i damaged one of the cables when i installed a few floorboards in the loft. Whats the best way to check the cables? resistance meter? thanks
james.wilson Posted January 25, 2009 Posted January 25, 2009 Yes. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
john@total Posted January 26, 2009 Posted January 26, 2009 No carpets, But most of the cabling runs up to the loft and then down the walls to the sensors or keypad. I'm wondering if i damaged one of the cables when i installed a few floorboards in the loft.Whats the best way to check the cables? resistance meter? thanks Hi 1st thing disconect the bell cable and place link between 0v & TP, replace blown fuse. Try system again, if tamp fault still occurs change battery. If everything is now fine you need to trace the bell cable fault.
