I Have To Admit To Defeat!
JasGun
Thanks for the quick reply.
I swapped the yellow & black roun.
It worked.
But then after a few more menu settings
Line failure came back!!
I can go to wickes or B&Q, what d I need to test 50v? sorry if stupid question?
It worked.
50vDC means theres a line there. Just a way of confirming.
Once again Thanks all, I think its sorted.
I am now a proud owned of a multimeter, still no real clue how to use it.
But did find volts on the phone line.
Stripped the wire a bit more & reconnected the yellow & black wires.
Seems to work fine now, can arm & disarm.
Just need to test if it calls me if the alarm goes off.
Is the the best way to test if it calls me, is actually set the alarm off?
I'm not trying to be facetious, but that is the ONLY way to test it is working correctly, after all that's why you have it in the first place. :lol:
