mikeharvey Posted January 26, 2009 Posted January 26, 2009 Hi everyone, Im just looking for a little bit of help. We have the Eurosec Cp8l Lcd alarm installed and have had no problems with it. Ive just realised you can set it on with only certain zones working but i can't figure out how to do this. Can anyone give me some advice. im really just looking to have the external alarm on when in bed (the front back doors and windows but not the movement sensors). Does anyone know how to do this? It says in the manual how to create seperate settings for the zones but i cant figure out how to add the zones to the setting. Thanks for any hekp you can give.
wilks121 Posted January 26, 2009 Posted January 26, 2009 Hi Mike That part is done through engineer programming. I take it you dont have access to this, so you may need your installation company company to revisit. You could try the usual part setting when it wont annoy any neighbours, which is code then 1 instead of yes. Wilks
alterEGO Posted January 26, 2009 Posted January 26, 2009 Hi MikeThat part is done through engineer programming. I take it you dont have access to this, so you may need your installation company company to revisit. You could try the usual part setting when it wont annoy any neighbours, which is code then 1 instead of yes. Wilks They can also be omited via 'delete zones' in the user manual, but you have to do it every time you set.
mark auto Posted February 3, 2009 Posted February 3, 2009 They can also be omited via 'delete zones' in the user manual, but you have to do it every time you set. i think they should change the wording of that, sounds like the zones will be permanently excluded from the system, why cant it say "omit zones" like everyone else??
james.wilson Posted February 3, 2009 Posted February 3, 2009 cos its risco? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
Gopher Posted February 3, 2009 Posted February 3, 2009 i think they should change the wording of that, sounds like the zones will be permanently excluded from the system, why cant it say "omit zones" like everyone else?? Yes like redbull said "cos it's risco" and I mean what would be the point in being like every other alarm out there, they just have to word / do it differently I mean part set on them is interesting to set up.. Intruder / CCTV / Access Control Technical Support Personal Subscriber to the "K.I.S.S" principle, that's Keep It Simple Stupid, are you?
Rulland Posted February 3, 2009 Posted February 3, 2009 Very!!!-soddin attributes etc-yep,different aint the word!..... Like anything tho-easier if you done it b4.
