Alarm Co Posted January 30, 2009 Posted January 30, 2009 is anyone else having problems printing certs off ssaib web site ? or am i doing sumthing wrong?, its pretty straight forward is cert?
Guest RJBsec Posted January 30, 2009 Posted January 30, 2009 Had no problems recently, what problem are you having?
Alarm Co Posted January 30, 2009 Author Posted January 30, 2009 Had no problems recently, what problem are you having? to be honest never used it before off the net , but clicking certificates direct,,print certs ,,,, issue inclusive ,, filling all fields,, and then issue cert but nothing happens? i goto be doing it wrong aint i??
Guest RJBsec Posted January 30, 2009 Posted January 30, 2009 Have you got Adobe Reader installed on yor p.c.? The software creates a .pdf file to print out, if you haven't got it you can't print it out or even see it - there's a link to download it on the site. Also check you haven't got popups blocked as the .pdf displays as a new popup and some popup blockers will stop it being viewed.
Alarm Co Posted January 30, 2009 Author Posted January 30, 2009 no pop up blocker yes got adobe, using mac?
Guest RJBsec Posted January 30, 2009 Posted January 30, 2009 What happens if you click on 'Reprint Certificate', do you see the certificate that you just completed? Can you print it from there? (You need to refill a couple of fields).
Alarm Co Posted January 31, 2009 Author Posted January 31, 2009 no ? no good does nothing? all required fields are filled ?? no pop up blocker on ? /
Guest RJBsec Posted January 31, 2009 Posted January 31, 2009 If you can't see it as available to reprint it obviously hasn't registered on the system so its a problem after entering the fields. I can't think what it would be so best speak to the office on Monday and see if they can offer any advice, I don't use a mac but I would be surprised if it hasn't been prepared for both windows and mac.
