Flashing Flood Lights
hi
is it possible to make 2 x 500w pir flood lights flash on and off when the alarm goes off, the paniel is a texecom prem 24 if it can what would i need ie flashing realy
Cheaper way would be to use one of those dummy flashing LED modules. Cut one of the LEDs off and use it to power a transistorised relay which in turn feeds a bigger relay which switches the live feed to your floodlight.
Trade Member
Could you make a prems output follow a fire signal, that would give an on/off on most panels? Save buying a timer relay/module?
My Amateur Radio Forum
Or as Antinode-there's numerous ways of achieving it-but as I said be wary of the on/off frequency of the light/lights.
Yep see your point,You still trying to switch a 230v light on/off via a 12v dc system and would require a relay though:whistle:
On my house i have a set up like this.
Old bell timer with LED, starts flashing slow (set at 10 mins) go' s faster and faster until it latches at zero mins.
I cut ou the led and made it drive a RB007 relay, this relay drives a 10amp 12v coil relay switching 1kw of flood lighting.
It starts of flashing slow and speeds up the longer the alarm goes off, after 10 mins it latches the lighting on fully.
Do you too much spare time Andy?
Now I like that Mate-sounds so much more professional than-'Yep is poss'- :rolleyes: and somat that I hadn't thought about-so now you get the browny points-and I'll make a note of it for future reference ta. LOL.
