Accenta Mini G3 Intruder Panel
angellonewolf
hi thanks for looking any help given
work had a breakin did not get far as other security stoped them (the alarm did not put them off lol even when going)
my own house had a pir fault after 10 years of installing never 1 false alarm.Got back home next day had a next door come round said your alarms going off and at a bit annoying only time it goes off they never had a look or try to contact me :ranting:
im now thinking what is the point on an out side bell box/strobe
now to the questions
i installed a accenta mini g3 intruder panel system 2/3 years ago at work all works fine (this is where i want to install the dialer) i hope with a bit of time (have not had look in the main box but from instructions will accept a speech dialer make honeywell ade but from what i have found on the net people have been having problems when the unit calls a phone you only get part or nothing of the automated message is this true ? i know this is only a
I find the only drawback with the Menvier is it will only store 4 contact numbers-I prefer the Texecom-8 numbers and four inputs as opposed to the Menviers three.
These days most people have a mobile so going on that in effect you can only store 2 contacts-home and mob numbers!.
hi and thank you all for the replyes might have to go for the texecom ? or mevier
any help with the wiring is it standard throught most panels
and any info on the
what is 3 trigger inputs programmable as active high or low i assume set alarm off when
volts are 0 or +?volts
thanks angel
and any info on the
thanks angel
go for one of the menviers (ie 1, 2 or 3)
All diallers wire basically the same
trigger wise you are right.
with the power installed
can you install only the bell output to the 1 trigger to activate the alarm dialer
if you want to install to an older alarm panel with most of the dialers
